What's the best practice to mount these rock sliders to my frame. Drill matching holes, tap them to the bolt threads and bolt them directly to the frame?
Thanks friends!
They should mount to the body, and not the frame.
Yes, they will rub rocks, I got these for free, so its not too big a deal, but question: why should they mount to the body, isn't the idea that they protect the body, and shouldn't the frame be stronger?
I will read through that linked thread shortly, thanks for the help!
Thanks for the answers everyone!up here in the PNW...
Welcome! After buying mine Jeep, an early change was to take the nerf bars off. Best is mounted to the tub itself.
My sliders now can take the weight of the Jeep without damage. The Warn sliders I have are not the best but are way better than the nerf bars.
Look here. https://wranglertjforum.com/threads/rock-sliders-rocker-guards-guide.8704/
Have you thought about making a change to that hood?![]()
Wildman, any favorite spots or secret trails?
Thanks friends!
Yes, the frame is very much stronger. The problem is not the strength of the frame but instead, the length of the lever working against it. The sliders you posted up have very long tubes to get them out from under the tub so they can get in the way between the rocks and the tub. That puts a lot of leverage against the ends of the tubes where they mount to the frame. Bolts will just pull out and flex so then the obvious solution is to make them very heavy duty and then weld them to the frame with some gussets. That will stop them from flexing but, it won't solve the big problem which is the frame just isn't rigid enough at the upper part of it through the body mounts so a hard hit just rotates the top of the frame inward. Due to the length of the lever, it only has to move a small mount for the slider to make contact with the body and damage it. And that my friend is how you stop from being obtuse while also being accurate.and shouldn't the frame be stronger?
I love my sliders - they mount to tub mounts, are full sliders, act as a step for the woman, and are very affordable.
https://www.hylineoffroad.com/jeep_parts/jeep_tj_rock_sliders_97_06_wrangler_tj
Since you're in Portland the nearest area to play is Tillamook state forest. Make sure you get the off-road sticker before going.
If you want to travel a bit there are spots in WA and central OR also.
The reason not to use those bars have been covered.
