I contacted Genright a few months ago about making the aluminum rocker without a step-received a firm “not interested “.
We can't even get the steel versions without a step we have to cut off, no chance they were going to do aluminum.
I was considering cutting the steps off my steel ones. Then I thought why not take them to a fabrication shop and having them make a set of aluminum sliders.
The Savvy aluminum rocker base (no slider) could be an option when they come back in stock.
Lightweight and no step, though I’m not sure I’d count on them holding up to hard hits without that steel slider.
So as far as steps on sliders go, other than appearances, is there a reason to not have the step (assuming they are structural steps)? Do they act as a lever arm on the slider and the tub and increase chances of bending the slider/tub?
I just don't think the steps are usable as...steps. Perhaps some of you with more experience will disagree. They seem too high, higher than the floor inside of the jeep, and seem to stick out so far they would be a hinderance to entry when I try to get in without using it as a step. I just want a thin rub-rail. When I called Genright to ask if they would make the aluminum slider without a step, my thought was to put a smaller piece of steel over it, making a quasi-Savvy slider, but it was just going to be way too expensive.
I think most that want a step overlook that very thing. I've shown lots of folks that to step up on the step requires that you lift your foot higher than the floorboard. It has never made sense to me to step up and then step down into the rig.
If you need a step, why not these...? Self retracting, no power required, quickly removeable, can be used with a lot of tub sliders, nearly impossible to see when retracted... But they are a little pricey.
https://mountainoffroad.com/collections/wrangler-tj/products/hide-a-step-black-tj
The step can also act as a lever arm against the slider and increase the chance of bending/damaging the tub and slider correct? Or is that not really a concern?
So you’re saying the step makes it easier to get in the backseat?For myself I never use the tube as a step to get in the driver seat. I and others do use it to get in the back seat.
I regularly have people sit in the backseat so this might be a pro for the genrights.
