It just has to be strong enough for your application. If you are going to build a steel rocker, I would think sticking to the single layer would work fine. Many people have been running that style in many areas with out issue
.1875" Steel plate bent with .25" Bend radius with the same three bends as the aluminum base plate. Keep the "kink" or 2 degree bend under the door jamb to help hide and sheet metal gaps and then two bends with the bottom resting on your tub torque box. If your willing to drill all your holes I would make them a little wider and longer then you think you need and trim to fit. Once you like the fitment lay out your holes. Time spent with a combination square making some good drawings should yield decent results.
To add, when I was working out the design for our DIY mini boatside project, the initial plan was to make them a composite similar to Savvy, but the thin 1/8" steel skin was simply to cover and protect the aluminum rocker. The rub rail is a separate component immediately below the door.
I eventually figured out that there was little to no weight savings and a whole lot of complications to the fabrication to create a tight fit between the layers. In this instance, a steel boatside made more sense.
To the original question, building a multiple layer steel slider serves little purpose other than to add weight and complexity.
