I feel like there's no general census on this, some people say that the TJ's cooling system sucks and others say it has more than enough capacity, but I'm just wondering specifically about coolant temps at idle. It was 90+ degrees today, and going through a drive through I watched the coolant temps hit 230 a couple times (OBD scanner) when I was sitting there with the AC on. The dash temp gauge stayed pretty much at 210, so it lies. Turning the AC off or increasing my RPM to 2k+ brought the temp down of course, but I'm wondering if this is just normal for these old Jeeps.
Reason I ask is because I've literally checked and replaced everything in the cooling system, used OEM parts, and it's basically brand new and has done this for as long as I've had it. I suppose I could have got a bad fan clutch or something, but I can hear it engage and disengage when I'm driving around on hotter days so I'm assuming it's working okay. Is it just normal for them to run hot when it's hot outside and you're idling? In other conditions, even when driving up the mountains when it's 115 outside, I've never seen the temp on my OBD scanner go above 215. It's only when idling. It never overheats, but does get pretty hot. As far as I can tell there is nothing wrong with my Jeep. I also have done several flushes.
I asked my mechanic about it and he says that it's normal and it's just that older cars with fan clutches were not meant to sit and idle for 30+ minutes in the heat. Thoughts? How hot does yours run when it's hot out and you're idling?
