No sir not that one the one he has next to it
The one that looks like this one,unless the man has m220 swapped his axle then ?
Rancho and Nth degree used to make them too.
Gotch i figured rancho but didn't see their signature red !
And "Nth Degreee" never heard of em till now sucks they dont make stuff no more,for the 30 secs of research i did seems like they had some decent stuff !
That's a great way to rob ground clearance!![]()
Me slam axle to rock a bit too much
rock break stuff
Jokes aside your right...
It’s from rough country. I got it for $50.
With all these dam parts I bought I couldn’t get the Barnett rear diff cover I wanted.
I recently welded about 3/8" of material that had been ground away on the rocks back onto the rear axle housing.
This is effectively hard facing and will last much longer than what was there.
Yeah im gonna have to do so most likely and hardface my axle and just burn rod after rod to hardface the bottom with
That'll be a ways later though once i decide to either brace my axle for when i weld new brackets once i tear my stock ones apart..
I wasn’t into Jeeps back then, but their stuff was pretty cool for the time.
I haven’t seem one of those skid out in the wild, but I’m not sure of their utility. This is my driveshaft after 2-3 trails. You can see some damage on the yoke and straps, but much more on the shaft itself. A skid wouldn’t help there.
My front DS is slightly better.
Gotcha.....only if 44s were like 14bolts to where i can just bolt on a Guard
If only someone made a skid that protrudes out to the u-joint kinda like what NextVentrure did !
Don't over complicate it. A few minutes with a MIG and a grinder is all you need. And skip the truss.
Still a great way to rob ground clearance. You can't help yourself, can you?![]()
Why no truss ?
Uptravel issues ?
Useless added weight and pointless reduction in up travel. If you need a truss, you really need a bigger axle. Get a bigger axle and you don't need a truss.
