For some reason the vibration got exponentially worse after putting the aluminum skid plate on and I’m not sure why. Prior to putting the skid plate on, it seemed to be down to a vibration at idle only which was somewhat tolerable. After the skid plate it basically rumbles/vibrates between 2 and 3k rpm and is no longer tolerable. It does it in first below 5mph so I’m fairly sure it’s not the rear driveshaft.
I spent a lot of time clearancing potential issues just in case but to no avail, the following is what I did:
-Fan hit bottom of radiator shroud, I trimmed it back so it clears
-Passenger side engine mount was very close to contacting so I filed both sides down a little, there’s a good 1/4” between now
-Exhaust contacted metal cloak oil pan skid plate, temporarily removed for now
-Exhaust contacted lower control arm mount on the frame, tightening up the bolts connecting the exhaust to the manifold cleared this (they were slightly loose and allowed the exhaust to swing
- Exhaust was hitting rear cross member of skid plate (raised up exhaust hanger mount at front cross member)
-There’s one screw coming down from the tub with a washer holding the insulation on above the muffler, it’s close but it’s not touching
-Double checked the tub above the t-case at the two high points on the drivers side, still no contact
After futzing around with it for a good 4 hours, testing driving and getting several burns, I said fuck it and took the skid plate off, but it made no difference.
I pulled the bolts for the transmission mount and got them centered and loose in the bushings (Blaine you were right, I had an extra washer on the serrated flange nut).
At this point I’m not sure what to do, but I’m glad I didn’t through the original skid plate and trans mount away.
