Skyjacker suspension and handling issues
rtd16
NY
I picked up an 04 TJ that came with a 4" Skyjacker lift. I'm not sure if it has the dual rate springs or not but it does have the Skyjacker lower control arms, shocks, stabilizing links and transfer case drop spacers. The Jeep seems pretty unstable to me with this lift (I've driven lifted vehicles before for comparison). I wouldn't say it is the 'death wobble' but it definitely seems to dive and leap when it hits bumps, a white-knuckler to drive.
I've never had a Skyjacker lift. Is this something corrected with a different set of Shocks - are the Skyjackers generally pretty good? Or is there something else to help steady out the handling. I'd rather not do a whole lift kit so I am curious if there are options out there. Thanks
Skyjacker is what most would consider to be a low quality brand. Definitely not something you’d want to waste your own money on.
Post some photos of your steering and track bar setup for starters. It’s likely that you’re experiencing bump steer or other issues due to potential drop pitman arms or drop track bar brackets.
Reactions: TheBoogieman
Here are pics of the current set up. Looks like a Rancho stabilizer. It looks like it doesn't have the track bar drop bracket. Not sure about the pitman arm.
  • Face Palm
Reactions: John Cooper
Thanks, I’ll check on the axle centering tomorrow. I’ve heard the term bump steer before, I thought that had to do with the parallelism of the track bar and drag link. They seem parallel to me. If I pull the drop pitman arm should I go with a track bar bracket?
All you care about is preserving the factory mounting locations for both the track bar and drag link. A factory pitman arm will do this for you.
If you go by what you think is parallel by looking at it you will be incorrect and misguided. Contrary to popular belief, from the factory the track bar and drag link are neither parallel to each other, nor are they the same length. However, both are in a proper relationship with each other. Do not screw this up.
Reactions: CMBD
No. Your track bar is mounted stock, the pitman needs to be stock.
The axles need to be centered.
You need to learn the dry test to check all connections.
You need to check your caster and make sure it’s north of 5 degrees.
That Jeep’s lived in a harsh environment and needs attention.
Thanks for all the replies. I opted for a stock pitman arm, adjustable track bar and new tie rods (I'm going to go ahead and do the ZJ upgrade). Parts should be in this week and I'll update when I swap them out.
While your waiting on parts start soaking everything down with Kroil and evaluating the rust situation!!!!!
Yes I am from the South and I think that rust would scare me away.........
Reactions: tnjeepguy
Well I swapped everything out today. Went with the ZJ tie rod upgrade, Rough Country adjustable track bar, new stablizer and stock pitman arm. Ensured the axle was centered, did a tape measure alignment as close as I could get on the wheels. It still drives and handles about the same.:( Here's a photo of the previous set up with lines showing the track bar and drag link line up. The photo before the work shows them way out of whack, the after photo shows them pretty close to parallel. I don't get it. I also aired down the tires from 32 psi to 28 psi before I did all the work. That made a difference but not much. Seems like all this work was for nothing.
View attachment 553253View attachment 553254
What size tire??? I'm running my 33 12.50 15 at 25-26psi.
