Slow cranking engine after rebuild
I’ve got a Mopar sensor coming, hopefully that does the trick.
Though I’m still a little on the fence. I do get spark on all plugs, wouldn’t a faulty crank sensor trigger something in the PCM to shut off the ASD causing a no spark situation?
If that don’t fix it,just keep the old one with you for a spare.
No dice on the crank sensor. Fuel pressure seems good at the rail port, as well as spark. I’ll check compression next.
Could the aftermarket cam sensor be an issue? I couldn’t find a Mopar when I bought it so I got Standard Motor from rock auto.
