That's the spirit! Mud is awful.![]()
I just hate to be the one guy out of say 50 people to get hydro locked that is the one thing I absolutely do not want, no way! I'm mean you're pretty much talking about a new engine at that point.
You are talking about a new engine at that point.I just hate to be the one guy out of say 50 people to get hydro locked that is the one thing I absolutely do not want, no way! I'm mean you're pretty much talking about a new engine at that point.
I have done plenty of water crossings as well as ling drives through deep water with my TJ as well as my old CJ5. I have never used a snorkel. I did plan at one point a long time ago of making my own snorkel and found the attached write-up at another forum and saved it as a PDF.
I have taken my TJ with the stock air box as deep as the bottom edge of the headlights with no snorkel. I have always been very careful and always knew how deep before I went in. I friend of mine with a snorkel actually floated his TJ across a deep water hole.
Now with all that said and my years of water wheeling under my belt here is my 2 cents as far as water and Jeeps.
Think of water a cancer, basically you will not see any issues until later in life. Water eventually will cause issues with starter, AC compressor, clutch and wheel hubs. I have gone through 3 starter. My AC compressor has been making noise since 2010 and about 2012 it finally died on me. because of all the crap in the water and vegetation etc.. I had to replace my clutch because the pressure plate got clogged up with junk from the water. My 6Speed NSG370 transmission is also on its last leg because Jeep never added a breather hose it it and I never knew.
Make sure you check and extend as high up as possible all the breather hoses (2 axles, Transmission and Transfer-Case).
Belt pulley bearings will also have issues as time passes by.
Avoid if possible long water exposure meaning long deep water. Try not to get stuck in the water because you don't want your Jeep sitting still in deep water.
Going through a small stream or a water hole that is more like a quick dip is not bad.
Water playground
Clutch
View attachment 53175 View attachment 53176 View attachment 53177
The fan clutch goes a long ways towards preventing that from happening.Don't forget that you can bend your fan and take out your radiator.
No doubt it happens. It would be interesting to know more about those where it did happen. Were they stock setups?It happens, I've seen it.
Stock as far as I know, many clutches don't let up when they should I suppose.No doubt it happens. It would be interesting to know more about those where it did happen. Were they stock setups?
If true, it sounds like the clutches weren't working correctly prior to the water crossings where you've seen the fan chop up the radiator.Stock as far as I know, many clutches don't let up when they should I suppose.
Some times you need a propeller too
Got any pics of your Windstar cowl intake conversion?I don't personally like the look of snorkels which is why I went with the Ford Windstar cowl intake. Doing that also gave me room to mount my ammo can OBA.
Post #14Got any pics of your Windstar cowl intake conversion?
