I have an 04 Wrangler with a 4" Rough Country lift I had installed 4 years ago and has worked great for me. A couple weeks ago I brought it in to balance and rotate the tires and immediately it had a Death Wobble. Later we found out the aftermarket wheels had no centric rings and the technician just didn't get one in the front centered properly on a front hub. Yesterday we rebalanced the tires which were right on and we also did another alignment. After getting the centering rings for the wheels the death wobble went away immediately. The tech also noticed there was a slight amount of play in the 2 upper OE ball joints and some play in one of the front axle joints. I decided at that time to replace all 4 ball joints and both axle joints....................... So here is the problem, immediately after replacing the ball joints and axle joints and realigning again the Jeep had a bad wander all over the road at 60 mph+ driving home. Wanders so bad its really not drive-able and I had to turn off the freeway and drive 40 mhp side streets the rest of my 30 miles home. It darts back and forth significantly over 60 so much that you cant drive with a car in the lane next to you without the risk of hitting it. I found it now also has memory steer. I can now turn a pretty tight turn and let go of the wheel and it continues to turn indefinitely.
I'm hesitant to believe like I've read in other threads that the issue is an inferior lift kit, pitman, control arm bushings, and others because before replacing the ball joints and axle joints yesterday it tracked straight down the highway easily without issue daily. It never had the memory steer or wandering ever. ZERO. It drove great! We don't use it for any off road use. We didn't use adjustable caster ball joints but i don't believe the OE ball joints we removed were adjustable caster either.
Since all of this didn't start until after replacing the ball joints and axle joints what do you think could be the cause and what might I do to correct the issue?
Thank you in advance.
