Stock Front Brake Hose Length?
starkey480
Garage crawler
Arizona
Hey guys trying to figure out if the previous owner used extended brake hoses on my TJ but can’t find the stock measurement anywhere. They are 19 inches long from tip to tip. Stock or extended? Thanks
I assume you have a lift and want to make sure they're fine? The best way to do that is to put the frame on jack stands, take the tires off, and droop the front axle. That'll tell you a lot.
Well more like going to order a lift and want to order everything at once... but just looked closer and there relocation brackets on there and looks like I can drop it down a good bit if need be!
