@Chris that's kinda my thoughts. It does come with a bolt on spacer between the Exogate an the factory carrier. From the installation instructions that's the best I can tell anyways. Thanks for your reply.
I appears to function similarly to the Exogate system, for a bit lower price. However, I see a couple of things that I can comment on:
If you're one to always rotate your spare in with the other tires, your choices would be find a spare carrier that will work with 33s, or go down to 32s or 31s. If you don't rotate in the spare tire, why not get an 8" wide alloy wheel for it - lighter, and easier to mount. I still believe the Exogate would work with your wheel/tire current setup, though. Were you looking at just the Exogate hinges alone, or their hinge/tire carrier combination?
http://gr8tops.com/shop/jeepmodels/wrangler-lj-2/tj-lj-exogate
I'm worried about my hinges and my tailgate as well, so I'd either get the exogate, or downgrade. I've thought about an alloy rim - however I don't think it'd be THAT much lighter?
I also was thinking about just mounting a 31" tire as my spare - and only running 4 33" tires?
Options:
- Buy an exogate
- Downgrade all tires to 31"
- Downgrade JUST my spare to 31" - albeit it may look funky
- Mount a 33" on my steelie spare and just wait for it to cause problems
- Mount my 33" spare on an alloy rim and roll the dice?
- Make some kind of steel shelf to sit beneath my spare tire, which is certainly possible
Because I've looked at the weights between a 33x12.5 and a 33x10.5 and there is barely a weight difference. When you go to a 31" tire however the weight drops a lot.
If it was me, I'd just save up the money, get an exogate and do it right the first time!
Isn't changing 5 tires going to run you more than $400 anyway? I mean, if you're going to spend the $$, you could end up with a better tailgate, tire carrier, and keep the 33" tires...just thinking out loud...That is certainly the right way to do it!
I just can't stomach spending another $400 on my Jeep, and end up modifying it even more!
I think I'm just going to drop to 31" tires completely. They are almost 1/2 as expensive as 33" tires, they are lighter, easier to balance, and put let stress on everything in my suspension. I don't want to get rid of my 33's, however. They look'a good.
Just so you know, I did not mean a new tailgate (although it would seem new with the HD Exogate hinges). I can see no down side to the Exogate system, other than the initial purchase price. I plan to add it to my Rubicon with 32" tires hopefully within the next year.Certainly a good point, however I want to keep my tailgate and my body as stock as possibly. Wheels and tires are a separate issue!
Just so you know, I did not mean a new tailgate (although it would seem new with the HD Exogate hinges). I can see no down side to the Exogate system, other than the initial purchse price. I plan to add it to my Rubicon with 32" tires hopefully within the next year.
It sort of seems like you're set on 31" tires...if so, go for it, it's your Jeep!
If your next question is can I have pictures the answer will be no because it's currently under 10 feet of snow in Tahoe
