It's Monday, so I thought people might like seeing the front of my Jeep being lifted up from the BMB tie rod. Enjoy!
Perfect!
Here's one. Still straight!Anybody can do that! Not everybody can show an after picture with it being straight.
#JustBecauseUCan
#LookAtMyRod
Anyone else see the irony that he is comparing his rod to a Johnson?
Can someone please take a close up picture of the proper position for the passenger side clamp? I just want to make sure I've got it correct!
I posted this over in @jjvw's thread - but for those that don't already have a correctlync and want this, you can just buy the individual pieces. I believe this list to be complete:
* CorrectLync Drag Link $358: https://www.rockjock4x4.com/CE-9701DL-TJ-LJ-XJ-MJ-ZJ-Currectlync-Drag-Link-Complete
* Steering Damper bracket $43: https://www.rockjock4x4.com/Steering-Stabilizer-Shock-Bracket-Kit-fits-1-1-4-Inch-Tie-Rod (thanks @JDM)
* BMB Tie Rod $185: https://www.shop.blackmagicbrakes.com/4340-TIE-ROD-HEAT-TREATED-4340-TIE-ROD.htm
* Currie TRE RH $82: https://www.rockjock4x4.com/CE-9701TRR-TJ-LJ-XJ-MJ-Currectlync-Tie-Rod-End-RH
* Currie TRE LH $82: https://www.rockjock4x4.com/CE-9701TRL-TJ-LJ-XJ-MJ-ZJ-Currectlync-Tie-Rod-End-LH
Puts you at $750 + tax and shipping all in.
[URL]https://wranglertjforum.com/th...re-i-want-to-build.9410/page-201#post-1047541[/URL]
I guess Rock Jock no longer sells the TREs? Savvy wants $50 shipping for two ends.
https://www.rockjock4x4.com/product...tment-tie-rod-drag-link-ends/ce-9701-rod-endsI guess Rock Jock no longer sells the TREs?
Check Summit?
Ok thanks, I'll give em a try if my order fails. I clicked on the links from from the post I replied to and it went straight to 404 so started getting nervous. Did a Google part number search and lots of stuff out of stock or item not available.
Did, it was either out of stock or item not available not sure which.
