Hey Guys
I have read a lot of posts about towing, but mostly related to weight. Not so much with regards to gears.
I have a 2002 TJ 4.0L 5spd. I currently have 31s now (2.5in lift), but will be getting 33s.
I was all set to re-gear to 4.10s but then as I consider pulling a trailer I am thinking the 4.56 might be better. I don't want to spin too high down the road as I usually drive to my destinations as far as Oregon (from Los Angeles) so was thinking go with 4.10s. I did the grim jeeper gear calc (attached) to compare the RPMs at different speeds and the 4.56s don't seem bad. So can anyone comment if there is a material difference between the gears when towing in town and / or hwy between these two gears?
Probably worth noting, I don't do a lot of crawling, but spend a lot of time off-road getting to fishing and hunting places, and great places to camp.
lastly, since I am going to re-gear I think I will put in an LSD. I do spend a lot of time in the snow and rain. Question is, is there a brand people recommend and should I put the LSD in both the front and rear? Or just the rear?
Thanks guys
Thanks guys
