Sure you can pull it. The question is can you control and stop it in an emergency situation? Tongue weight is a major limiting factor. 10-15% of trailer weight should be on the tongue for stability. My 08 Sierra 1500 is rated to tow 10K lbs but if I hook up my 7K lbs car hauler the rear sags to the point of almost hitting the bump stops.
Most owners manuals say properly equipped trailers. This means brakes on the trailer and a load distributing hitch. The manual states using a LDH for trailers over 1K lbs.
Factor in a lift. Not only does a trailer place a longitudinal load on the tow vehicle but it imposes a lateral load also. A lift multiplies this force the higher it is.
Other factors to consider are wheel base of the tow vehicle, rear axle load rating, class rating of the receiver, frontal and side area of the trailer for wind load (my 05 manual state no more than 25 sqft) and distance from the hitch to the axel on the trailer. The manual also state to change the fluid and filter in the trans every 60K miles if regularly towing more than 45 min at a time.
I’ve towed trailers hundreds of thousands of miles across the country over the years with the only issues being blown tires, the occasional spun wheel bearing and 1 blown trans on my 95 F350 pulling a 6% grade pulling a 18K lb 9’ tall box car hauler.
