Transmission leak
Nbergquist
Pittsburgh PA
I just had my transmission rebuilt and in the rebuild I had my mechanic relocate the vent. I ran a hose from new location on top of transmission to top of firewall. With ARB breather kit.
Problem I’m having is a get periodic spurts of fluid from hose when driving.
What could be causing this
  • Wow
Reactions: Jerry Bransford
2nd this. I did this relocation and had it spit up ATF, I could also hear it gurgling through the vent tube when I was adding fluid. Turns out I had a low spot in the hose and some had pooled up in there and couldn’t drain back down.
I shortened my hose and made it slope down the entire way, problem solved.
