Great video, looks like a fun trip. I enjoyed the breakage footage at the end!
It is fun, and the video doesn't begin to do it justice. When you roll Dana 30, stuff like that is bound to happen at some point.
You're welcome!Great video, looks like a fun trip. I enjoyed the breakage footage at the end!
@jjvw what did you do to get it home? Pull the axle?
And what was done to the Dana 30 to get home?
Would be good info for less experienced people like me.
That’s what gallon sized ziplock bags are for! Dump the gear oil in, then toss the bag in the diff when you put it together. The bag gets shredded and gear oil is in. Obviously you want to drain it when you get home but that’s the least of your worries. A trick I’ve yet to need, but glad I picked up from an old-school wheelerTo get @hosejockey61 home, the ring gear was removed from the Dana 30. This meant draining the gear oil into a cooler, pulling the axle shafts and the carrier, removing the ring gear, re-installing the carrier and shafts, and figuring out a way to get the gear oil from the cooler back into the diff.
I helped with that...and figuring out a way to get the gear oil from the cooler back into the diff.
@jjvw Could you not have removed the axle nut, removed the unit bearing without the stub, removed the shaft, put the stub into the knuckle/inner C and then installed the unit bearing and the axle nut?
What’s the answer to moving the gear oil out of the cooler back to the diff?
Did you see the dirt every day where Fred tried to add a trash bag filled with fluid straight into the diff? He couldn't get it to fit but claimed it was a "thing".Used water bottles and a purchase y of tworley's air hose
To get off a trail it doesn't seem like a terrible idea.When I read about it years ago, I recall the trick was to use several smaller bags. I imagine they wouldn't be filled very full so you could stuff them into the crevices.
The stub shaft ear folded over. I needed to saw through it in order to remove the unit bearing and separate the inner and outer shaft.
From there, we disassembled the driver's side and removed the inner shaft. The outer was kept bolted to the unit bearing to keep it from breaking apart.
