Maybe find an early JKU with a blown 3.8. Brute it and throw the tons on. Its already wider and fit the v6's with dual overhead cams.
You're likely right, but I've tried to avoid being a JKU owner . My plan is to steal the back section and the back seats and try to fit them to the YJ Body, then cut them off right behind the seats and go flat bed. Probably add 24" wheelbase length, I figure Wheelbase width would increase with the axles I need for a bigger diesel and total length would increase around 4 ft compared to the YJ.Maybe find an early JKU with a blown 3.8. Brute it and throw the tons on. Its already wider and fit the v6's with dual overhead cams.
Yes there would be a width issue, but I mainly just wanted the doors and the openings only. Just so if I want half doors and windows, etc, I could find stuff off the shelf.So front cab half and engine bay is still a yj? Then jku rear doors? Wouldn't there be a width problem?
I'd believe it. I heard some rumblings with the COVID stuff and how it's affecting China and our imports.Just a note on the R2.8, i know a local Toyota engine swap guy has stopped support for the R2.8 because it's almost impossible to get parts. LIke months wait for alternator.
I agree, I would replace everything with 1 ton parts and beef up my brackets as needed.An IDI 7.3L or a 6BT would be too heavy for a Jeep. Even if it fit you would probably destroy the front end (Dodge trucks with the Cummins do that already). Even the Kubota diesels that I've seen on here swapped in are heavy considering their size.
You absolutely may be right. I mostly dismissed this idea at first and just thought about bolting a JKU body onto a Truck frame and adjusting that length as necessary. Then cutting the JKU and making it more of a flat bed setup.so why don't you set a Jeep body on top of a Ram chassis or something? seems like more what you're going for, maybe a custom tube chassis? the TJ is just not set up for something so large and heavy, it would be a crazy amount of custom work to make everything happy.
ya TDI availability is huge, can buy the whole spare vehicle with drivetrain for like $2K lol. Agreed the 2.8 seems like perfect fit for a jeep. Now that theres an OEM diesel option, we'll have to see how it fares.I'd believe it. I heard some rumblings with the COVID stuff and how it's affecting China and our imports.
The R2.8 is assembled or checked in the US and designed in the US, but they only sell like 500 a year in the US vs millions world wide and they have almost no labor or regulatory cost in China, hence it's not a US manufactured item with a perfect parts supply.
It's my guess the R2.8 days are numbered in the US anyway, which is kind of why I got one, because for a brand new engine it's not a crazy price, but I do realize that I need to get my parts on the shelf rather than wait to break down. That is a major drawback for the Cummins engine. That's kind of why the big diesels and the TDIs are of interest for me on my next build, but the 2.8 is a great size and engine for a TJ, until something breaks.
I do know 6BTs are occasionally swapped in mainly for show, I'd imagine. The axles are gonna weigh way more, the steering and suspensions will weigh way more, the tcase, the transmission, batteries, frame, etc. The Jeep frame is a pretty good frame, but may just simply be too small. I'll have to see how it's laid out and do some calculations and see what makes sense, and maybe something like torsion arms and a beefy crossmember and skid plate/armor setup can handle some additional loading if it's even marginal.6BT or IDI weigh 900lbs, that is alot of weight for a wrangler chassis. I do not know of alot of diesel swap people on this forum, but maybe researching Pirate4x4 to see who has done a swap like you have in mind. Could you do it- probably-yes; but are you going to enjoy it after you all done? I concur with @pc1p, it is heavy engine.
Maybe to help put some perspective on this is what is going to be the main purpose of this build? Diesels are engineered for heavy work, running long hours nonstop. Gasoline are more for the consumer, everyday use, short term driving, etc.
Of course if something like a V8 diesel won't physically fit, then the issue is moot. I think it would be fun though, but I could certainly find some pretty good 1 ton frames out there to work with. It would make geometry easy, but I don't think veering slightly away from the Jeep geometry would be the end of the world either, but I might just need to be looking at putting a Jeep tub on a 1 ton. I'm just not sure.
Well there's 2 OEM diesel options for Jeeps, as far as engines I think. I'm sure there's some variance in those different engines and stuff too.ya TDI availability is huge, can buy the whole spare vehicle with drivetrain for like $2K lol. Agreed the 2.8 seems like perfect fit for a jeep. Now that theres an OEM diesel option, we'll have to see how it fares.
Yes the width really concerns me. Hence, why I'd almost rather beef up a Wrangler frame.I concur it would be easier putting the tub on an established chassis, as the drivetrain is engineered to handle the diesel. If I were to do it, I would do it that way, but what about width? Those tires and axles are going to be way out from the tub, and going to need wide flairs, and at that width depending where you are at, you may not fit down some trails.
