Water dripping at idle
Super Kev
Clovis, CA
I've recently noticed what appears to be water (it's not slick, pretty clear, odorless) dripping from my skid plate at idle. I would have assumed it was AC condensation but I haven't been using the AC. I recently replaced my stereo, speakers and sub so I've started the jeep just to test that everything was working and right after is when I see a small wet spot with a slight drip from the skid.
Is this common and normal or a sign that something is failing? I'm not mechanical so any help is appreciated.
2005 X, 108k
I'm pretty sure its the weep hole in the Stock Muffler. If you look at your muffler near the back of it is a really small hole that lets water out, I thought it was odd too when i first noticed it but turns out its normal condensation from the muffler.
Check back there and see if that's where its coming from.
Oh just to add yes that's normal nothing to worry about if it's coming from the muffler.
I used to have that until I recently changed my muffle. Now it appears to be gone. So........
