What causes the backflip rollover?
limitz
Seattle
Was watching a vid of Jeep rollovers. I noticed a lot of them were backflipping when trying to climb an obstacle. First one in the vid is here, but I noticed multiple:
NSFW
What are the main causes of these rollovers, locked rear diffs but open front? Too much gas at the wrong time?
freedom_in_4low
I'm a rooster illusion
Arcadia, OK
To bridge the gap a bit, long arms in TJs tend to have low antisquat which makes the rear squat when you give it throttle. So you get up on a steep obstacle, give it a bunch of gas and the geometry pulls the chassis down toward the rear axle, then once the CG gets behind the rear axle... It's going over.
Jablinski
Mud as Clear
Colorado
Lots of long arms in that video. 😉
A few poor acceleration/ brake vs. clutch or neutral...then brake situations as well.
Saved myself a few times by giving preference to blind reverse downhill over blind forward up
Reactions: lBasket
jjvw
secret beadlocks
Colorado, USA
It makes you wonder how many of those were autos. 🤣
Reactions: Jablinski
Jablinski
Mud as Clear
Colorado
Too much traction, too steep and too much gas. The suspension isn't a big part of it.
In my experience I've noticed that low antisquat is an issue that long arms exacerbate on TJ's. If the rear squats while climbing a steep obstacle, it throws the front rearward toward the tipping angle.
Slamming the gas pedal to the floor definitely doesn't help the situation either though 🙃
JMT
Saxum Erepo 🪨
NSFW
I don’t think this is mainly due to geometry issue, but the rear locker. It keeps pushing, and if you’re in an auto and don’t slip into neutral or a manual and don’t push the clutch you’ll keep going. Braking is a no no. Gassing it just exacerbated the problem. Going downhill is obvious. Getting sideways is dumb. Love how the dogs escape.
