Why don't we make WTF forum shirt with the firing order?
And a bunch of other useful stuff...normal fuel pressure for one...
-Mac
How about “Low CG” and “Rock out with your snorkel out”
-Mac
Still chasing a misfire cylinder 4 code. So far I've replaced the spark plugs (whatever Jerry recs, don't remember), crank position sensor (NGK), cam position sensor (NGK), throttle position sensor (Duralast), PCM (Wranglerfix). Did a compression test and cylinder 4 is about 4psi lower, but all within a reasonable range. Uncle recommended getting the head off to a machine shop to make sure everything is healthy. Jeep is at 10k on the odo.
Ialso have an evap code, could that be causing an error? Picked up a new fuel rail with the schrader valve to confirm pressure, but haven't installed it yet.
"GM filler hose fix" and "spit flames and pop"
-Mac
-Mac
Well I just walked in the house from doing this.
Hopefully my buddy's radiator shop has the top tank so I can get it replaced.
If not I will have to buy a new radiator.
Went from the above to this picture below.
Filled up with fresh coolant, topped off the ATF.
Ran it in the shop and got it up to temp 3 times, topped it off one last time.
Took it for a 30 mile test drive, pulled it back in the shop and everything was perfect.
I'm calling it a good day!!!!
Torque values on the back, like bands do with their tour dates.![]()
