That thing is sweet! What are you plans?
Awesome!
If you can, weld another bolt to the head of the striped bolt then wrench it out.Changed out the steering gear box, which led to changing the PS pump reservoir — that little 90 degree nipple on the return side is awfully fragile.
Plans were to also change the front output shaft seal on the transfer case. Got the skid plate down easily, got the front of the drive shaft unbolted with no problem, got three of four of the bolts at the rear of the drive shaft undone with no complications.
The last bolt head stripped. Nothing will grab it enough to back it out. The bolt head flange sits in a recess, so cutting the head off isn't an option without damaging the yoke. Probably going scorched earth and cutting up the yoke to free the thing, and will replace the yoke.
Are you saying you had TINT onstalled on your entire windshield?I recently had full tent on my windshield installed, so I absolutely had to have some kind of an upgrade.
I popped the hood and opened Pandora's box. The task of installing the ARB twin compressor w/ MORE mounting bracket has taken interesting turns- most were known ahead of time.
Turn 1: ARB interferes w/ SPOD controller, so mod SPOD bracket.
Turn 2: ARB interferes w/ K&N intake. I sourced an OEM bracket and did some trading.
Turn 3: Stock air filter housing interferes with the winch interrupt solenoid that I attached to the fuse panel bracket. I bend a 90* return in the fuse panel's bracket and mounted the solenoid. So, had to flatten out that bend.
Turn 4: Need to relocate the solenoid, which will likely require replacing the cable leading to the battery, and possibly the SPOD controller.
Good times. And this is why I don't have the appetite (or aptitude) to deal with fully custom suspension systems. . . .
Yeah, it must be tint. You can't install a tent on a windshield. You'd have to onstall it.
iPhone autocorrect - but I think you get the point.
While you have the fenders off take a look inside the bump stop mounts and clean out the crud that tends to accumulate.Took the grill off to repair the broken body mount bolt.
While I was there I removed both fenders so I could clean and paint as much of the frame as I could get to.
Changed all radiator hoses, heater hoses, power steering lines, brake lines, flushed brake fluid and power steering fluid and belt.
Next is replace rest of body bushings. Overhaul Dana 35 to a super 35. Maybe regear and add locker's!View attachment 132662
