What tire size?
MillerLikesJeeps
Delaware
I can’t figure out what size tires to get for my TJ, currently it’s running on stock 15x7 rims, with 235/75/15R tires, I have a set of 15x8 rims for it. I just want the car to look a little beefier. I do need to be able to drive in Snow, that’s about it. What size tires should I get? It’s a fully stock 2.5 TJ, no lift, but I plan to do something in the future.
I would go with 30x9.50-15.
It was offered from the factory and shouldn't kill your 2.5.
Good combination of moderate looks and decent performance.
When I had my 97 2.5 TJ I ran 31s without a gear ratio change. Looked good but it suffered a bit on the hills. 30 is probably the better choice. Love my LJ but miss the little sport
When I bought my '97 2.5, it already had 34" TSLs on it with factory gears and it also suffered. On I-20 from LA>TX and basically flat I couldn't use 5th gear. I re geared to 4.88 and then it was fantastic.
I also 5th the 30" rec.
I was in the same boat with 29” tires and the 2.5L. I recently upgraded to 31”x10.5” on Canyon wheels, w/o any lift.
No interference turning full L&R, but I also have some 1” lift springs and 3/4” coils spacers waiting in my garage, just as soon as I have time to install them. Daily driving, no lift is not a problem, but there would be contact doing any serious off-roading.
For the gearing, I was pleasantly surprised it didn’t feel as weak as I anticipated. If I lived in the hills or mountains, re-gearing would be a priority for me. But it’s very flat where I live, and not a priority at this point. I just changed the speedometer gear.
Reactions: PTMTJ and MtPockets
Decades ago, I had a buddy that had the same dilemma with his stock manual 4cyl YJ. He wanted a beefy tire without destroying drivability. He ended up putting on 29x10.5-15 TSL Thornbirds and it actually drove great city & highway. Keep a shorter height tire and go wider like he did to preserve your factory gearing advantage.
