Where are you mounting your on-board air compressors?
diggerwolf
Van Alstyne, TX
For airing tires, not lockers.
I'm sure it's been covered but my search isn't coming up with anything.
Thanks!
Stock AC compressor location
I don't have abs, so I removed the abs tray and built a mount that slides down behind the wheel well.
ABS tray. It does get hot with the pre-CAT's right there, but I haven't had the thermal protection go off on me yet. I didn't have to remove the fender to get the ARB single in place - just a little bit of wiggling.
Reactions: DougyintheBushies
Keep in mind that 12v compressors get HOT and they'll shut off on you when airing up once they get hot enough. Mounting them inside the engine compartment can cause them to get hot more easily and shut off more often while you're trying to air up.
Reactions: Artsifrtsi
Where do you keep yours?
