Finally got the Auxbeam 8 switch panel installed and can move on to installing all the accessories that will be switched. I'll be doing a writeup on it shortly. Adding flush mounted aux reverse lights to the rear bumper and need to pull wire from the cab out the back to the rear bumper. I figure I should follow the wiring for the tail lights and run from the opening under the rear corners to the bumper (assuming the tail light wiring comes from inside the cab).
What is the cleanest route out of the cab assuming I run along the drivers side kick panel where the harness is?
