Hello guys, just like everybody with a jeep.... I'm wondering what to improve and I'm considering priorities... and since opinions and advices are always welcomed I would like to know what do you consider should be next... I already have a pretty decent rig (06 TJ rubicon) so lockers, Dana 44s, lift, winch, ZJ tie rod conversion, DC driveshaft, adjustable rear upper control arms, 4.10 gears and recovery gear is already checked... so I'm considering a few different things to upgrade now and what I consider to be most important.
1. Revolution Gears to upgrade from 4.10 to 5.38s (tranny 42rle, oem lockers) I dont use the jeep a lot in the highway but still... I want more power!
2. Rough Country or barnes transfer skid plate to gain about 2 inches since I already made all the improvements needed for the mild tummy tuck (MML, BL, compressors relocated) (I know Barnes 2 inch drop is better, but I think it needs a lot of stuff to do to their skid plates)
3. Black Magic Pads.. the complete kit I think is a bit expensive so.... I will start with the pads and see from there...
4. Lower Control arms from Core 4x4 with JJ in one end, I currently have some skyjacker with poly bushings in both ends.... I hate them..
5. Metalcloak oil pan skid plate (not really a super rock crawler, so the expensive and fancy UFC is a no-go)
6. 35 inch tires.. (315x75r 16) currently I have 285x75r16
7. Chromoly shafts but only after I broke one, since I'm not a big gas pedal guy while wheeling.....
what are your thoughts?? am I missing something? do you consider that my priorities are not according to the common sense? thanks!
