Absorbed Glass Matting.... it is still a conventional lead-acid battery design but the acid is not a liquid, it is a paste that is pressed into woven fiberglass matting which is sandwiched in between the layers of lead.
An AGM battery's design is solid so it is far more resistant to being damaged by shock, jarring, etc. encountered while offroad. Conventional 'wet' acid design batteries suspend their lead plates in liquid acid and the lead plates can be broken off by impact which shorts the cell out.
Where Jeeps that go offroad are concerned, AGM is generally always a better choice.
This is how your Optima's AGM cell design compares to a standard AGM design... you get less battery for your buck in the same space with Optima's. Optima of course is on the right.
