Which JKS Front Track Bar?
Alatex
Alabama
Ok so I have a 4” suspension lift and that’s it with no body lift. Which specific JKS track bar should I get? I see they have one that says 1”-3.5” one for 4”+ and then the HD one that doesn’t seem to specify lift.
Ok the so the HD one (OGS128) and the OGS125 (the one that says 4”+) will both fit apparently?
I have the JKS bar on the front of my Jeep and have no complaints. The only modification I made was to install a factory Moog bushing on the axle side to eliminate the poly bushing it comes with. Amazon has a good price $209.63 on the track bar right now.
https://www.amazon.com/gp/product/B00DRZ7EOK/?tag=wranglerorg-20
https://www.amazon.com/gp/product/B000C57YMU/?tag=wranglerorg-20
the moog part that you added.... is just a direct fit replacement? I just got the JSK 125 and I was wondering the same, which would be the best replacement for the poly bushing.....
For my JKS 128 track bar the Moog bushing fit perfectly. I used the Moog K7252 bushing and installed it using a ball joint press as I didn't have a shop press yet. I used the K7252 since my track bar mount had already been drilled out. I believe you could use the K3147 if you still use the factory 10mm.
I got the idea from following the thread.
https://wranglertjforum.com/threads/track-bar-adventures-with-andyg.34654/
