Windows Hemi?
Yes it's the Hemi TJ form AZ with the bad transmission.
I'll be parting the TJ out once I get the parts off it I want/need.
The widow who sold it to her friend.
Windows Hemi?
I missed something......... What happened to the Magnum??
After I'd gotten the heads back & reinstalled I was still having the low oil pressure issue so I had pulled the engine to try and figure out why. Well once I got it torn down I found out that I had a cracked block underneath the #4 cam journal. Had a lot of speculation as why and what had caused it but it still meant that I had to start over again and build a new engine. I'd found a block and was fixing to take it to the machine shop when this Hemi Jeep had popped up For Sale.
Then the owner couldn't sell it because of the bad transmission and had PM'd me & offered it to me for a HELL of a price. Considering that I can sell the hardtop & full doors for a reasonable amount to compensate for some of the cost I decided to buy it & am going to swap the Hemi into my TJ.
Oh damn! That's a bummer!
It seems to be a theme with this build. Hopefully this will be the final obstacle.
In the immortal words of Rascal Flats: “God blessed the broken road, that led me straight to a Hemi…”
Or something like that.
Nice. That's definitely Hot Wire. I joked when I had mine done that Chris needs to up his label game...
Get er done! I'm going to Moab 9/14 - 21.
Wildman - You have made a good decision and I am very sure that you will love and enjoy everything when complete.
Hope you're right.
I am sure you already know but it's called a Hemi but it actually is not. If you take the head off and look at the combustion chamber you will see.
I've got to play with my label maker and see if I can get them closer to stock. But Chris is great to talk with a load of information.
Just got my invoice from JeepSpeed Shop for the motor mounts & York mount. He's also looking to see if he's got a Premier Power welder alternator from when he had a TJ. Thinks it's in a trailer but accidently left the keys to the trailer in a customers rig. So I might luck out on that too.
Will have to order the hose kit from Red Rock and then get a new condenser since mine was removed when I'd done the Magnum swap and I don't know where it ended up. Wizard Cooling sells one that I need to call them about and see if I can make it work or if I'll just need a stock one.
Once I've got it installed I'll have to test out my latching relay setup for the O/D and see if I can make it work.
There's a condensor in a certain 2000 model TJ that's REALLY accessible to you... SInce the Compressor in it is siezed up I don't think anyone would notice it missing...
Just say'n!!!
She might notice it gone when I have the front of her TJ torn apart... Guess I should be buying some A/C tools so I can fix mine & then hers. I've got the compressor that came off my 4 cylinder, I think it'll fit.
