Can that be welded?
Can that be welded?
No those bearings don't look fine they are chewed to shit
Rick, I'm so sorry to see those cracks. That totally sucks. Do you think the cam bearing install cracked the block or bad cam or something else?
Usually yes, but it needs to be a very competent machine shop to get it right…
Unless the block is a rare find, it’s not worth it. I would always be worried about that block. I’d get a used block and start fresh with measurements and machining…
I would have the camshaft (especially the cam) and crankshaft checked as well. Just to make sure they were true…
I think it was the valve springs binding and then breaking the one rocker arm & then installing the steel rocker arms. I'd say that the push rods are strong.
I agree with you on this. And like I said I found a used engine a little over an hour away from me. So I think I'll go pick it up.
Smart to just go get the other one. You may be able to sell off some of the parts you won't be using using to recoup some $$. I was able to do that when I bought a different motor after I had a seized piston. I was able to sell the old block, heads, cam and crank.
Man, that sucks. Wish I could do something.
Its been a couple of weeks since I’ve caught up on your thread, Rick. This SUCKS. I’m hoping for some magic here because we all want to see you and your Jeep in Moab this June.
The main and rod bearings are not “chewed to shit”. Those cam bushings are “chewed to shit”.
Here's a close-up of that journal. I had my numbers wrong. This is the #4 cam journal. The two that were spun are #2 & #3.
I didn't drop it off the workbench BTW... But I'm still FUCKED.
What year/s is the block from, I can look down here in texas
I'm at the VA CLIMB center today using the robotic foot. It's made by a company called HumoTech. This foot can emulate different prosthetic feet by a software and circuit card change.
