This doesn't need to turn into a Manual or Automatic debate.
Rubicon88,
All those types of terrain you listed are what I wheel on here in WA and I run an auto tranny. I use to be a die hard manual tranny guy too but once I was injuried I had to switch to a automatic transmission. Would I go back now if I had the choice? Nope not likely.
You obviously haven't used more modern autos on the trail by your comments because that is how I use to think also.
And my 46RE isn't even CLOSE to being as modern as some of the new 6-10 speed automatics offered now. And you can choose which gear to be in and they do offer the same compression braking that a manual transmission does.
About the only thing you can't do in a auto that you can a manual is to compression start your rig.
Rubicon88,
