Maso
Like I said, it's all done and running fine. This is on a export RHD TJ, so if something looks strange, that's why. No longer do I have to press the OD switch every time I start up. I managed to pull the wires out of the connector, just had to insert a pin in and lift up a little tab that holds the wire in. The pin worked, but something a little bit stronger would have been good as I bent the pin trying to lift the plastic tab, it did work though. Then I stripped some of the wire bare and soldered on the ones from the relay. I didn't want to cut the wires. Then I slid two pieces of heat shrink over the joins and inserted the wires back into the connector.
I have put the relay in behind the glove box since there was a tab there I could bolt the relay bracket to.
