Blaine, do you mind detailing the advantage/ differences between the 4340 steel tie rod and the "Ultimate" 7075 aluminum version from Savvy?To be very clear, this product was only ever designed and built due to all the detractors that said the Currie failed when they landed on their tie rod or bashed it into a rock and bent it. If you drove it home or back to camp, that isn't a failure. John did a great job with his product, it is designed to bend and absorb the punishment without transferring too much of that load upstream to other components that are harder to repair.
Think of it like a crumple zone on a car in a frontal impact that protects the driver.
I got tired and weary from explaining it over and over and finally said "fine, you want one that you can't bend, here you go, now don't call me if you break something else". Fortunately, the very high level of toughness and resilience mitigates some of the upstream transfer, but I would never promise that is enough to be wholly smart. To date, I only know of a single incident where something else failed and given what I know of what happened, I suspect the same failure would have occurred with any tie rod. You can't drop from a good distance, land on the tie rod right next to where it attaches to the steering arm and not expect something bad to happen.
The Savvy one is larger and runs into more things when you cycle lock to lock. That is the biggest complaint I get when folks have asked me to make these again.Blaine, do you mind detailing the advantage/ differences between the 4340 steel tie rod and the "Ultimate" 7075 aluminum version from Savvy?
As soon as they get back from heat treat. I put an estimated ship date on the website of a month out or 2/15 as a cushion that we should be able to beat.How soon will these ship?
Are they both about the same in terms of toughness/ resistance to bending?The Savvy one is larger and runs into more things when you cycle lock to lock. That is the biggest complaint I get when folks have asked me to make these again.
BMBAre these on black Magic’s site or savvy?
I don't know. I should get some pics and put them up of the one I have in my driveway. We installed some PSC stuff on it awhile back. While it was here, I noticed the draglink was flattened out some, lots of rock rash from playing in JV, so we pulled it and added some bend. When the owner picked it up, I asked him why he picked the heat treated tie rod.Are they both about the same in terms of toughness/ resistance to bending?
Thanks Blaine. Here I was anticipating a lengthy explanation on metallurgy or how heat treating modifies the grain structure...I don't know. I should get some pics and put them up of the one I have in my driveway. We installed some PSC stuff on it awhile back. While it was here, I noticed the draglink was flattened out some, lots of rock rash from playing in JV, so we pulled it and added some bend. When the owner picked it up, I asked him why he picked the heat treated tie rod.
He related that he had no idea what I was talking about, he ordered some Currie steering from Savvy many years ago and that's how it came. Well, you done good because you have dragged that stuff over everything, and it is still perfectly straight.
What makes you think I bash it into stuff, there are barely any scratches on it?
Oh, there are lots of scratches on it, they just aren't very deep because it is a much harder material and given that there is rock rash on everything else, it doesn't make sense that you could miss the tie rod.
The better story is how they came to be. Gerald built a rig and took it to JV on 37's. In short order he bent up his 4130 tube tie rod sleeved with solid. I had some 4130 tube heat treated and built him one. A few trips on that one and it was destroyed. I found some 7068 AL which is stronger or more resistant to bending than 7075 and built him one out of that. He went back out and ruined that one.Thanks Blaine. Here I was anticipating a lengthy explanation on metallurgy or how heat treating modifies the grain structure...
If something is holding up that well in JV then that's really all that matters. No need to overcomplicate the reason why.![]()
Savvy doesn't want them. They discontinued them in favor of the easier to build aluminum. We'll have them on BMB.
Not sure how I screwed that up.Didn't the older Savvy Ultimates come with the 4340 tie rod? I have the Ultimate, bought it in spring of 2017. Pretty sure it's not the same as the aluminum version they sell now.
Me either.Not sure how I screwed that up.
Sorry if it’s already been said but is this a limited run? I’m going to get currectlync eventually but need to know if i should order the upgraded tie rod now or will they be a constant product?
There’s a 250$ currectlync for sale near me… don’t know if that’s a good deal on a used steering setup or not….
Thanks, must’ve missed that somehow.Post #51.
Post in thread 'Toughness personified' https://wranglertjforum.com/threads/toughness-personified.58781/post-1042412
That's about what I paid in value of parts traded, so I would say it's a good deal if it's also in decent+ shapeThere’s a 250$ currectlync for sale near me… don’t know if that’s a good deal on a used steering setup or not….
This is about as good a photo as i have of it, unknown milesThat's about what I paid in value of parts traded, so I would say it's a good deal if it's also in decent+ shape
That’s what I paid for mine used. I had to replace the boots on the TR ends, which was about $35. At least the TR ends we’re still in good shape because they’re $85 a piece.This is about as good a photo as i have of it, unknown miles
