You can put your pants back on.Dammit! I always miss the fun threads…
Not paying attention to this thread obviously - is there something in the water? You guyz wanna know about sparkle panties, get yourself a pair or two and report back! Myself, I'd hold out for a gold lame' thong - I really should make myself one just to say I have it!Where the hell is @Zorba ?? I need to know about sparkle panties
FIFYYou can put your panties back on.
@Mrs.Apparition can you help out? We would need picsNot paying attention to this thread obviously - is there something in the water? You guyz wanna know about sparkle panties, get yourself a pair or two and report back! Myself, I'd hold out for a gold lame' thong - I really should make myself one just to say I have it!
Well, it isn't like you didn't already know that this thread is a perfect example of why we can't have nice things.I’m not touching this thread.
A bunch of deviantsWell, it isn't like you didn't already know that this thread is a perfect example of why we can't have nice things.
A bunch of deviants
We own Jeeps, that's already implied.A bunch of deviants
I was unaware. Why you gotta bust my bubble?We own Jeeps, that's already implied.
That’s a great oneOne thing that should be in here is if you can't raise something like a lower control arm mount, then what? A good solution is to cut 1/4" weld washers with a 9/16" hole in them that are 2" in diameter and weld them to the outsides of the mounts. Then trim off the mount to just outside the edge of the weld.
The value of mini skids on the front lower mounts cannot be overstated.
Have any pictures of this?One thing that should be in here is if you can't raise something like a lower control arm mount, then what? A good solution is to cut 1/4" weld washers with a 9/16" hole in them that are 2" in diameter and weld them to the outsides of the mounts. Then trim off the mount to just outside the edge of the weld.
I’m dumb and having a hard time visualizing this.Have any pictures of this?
Not at this exact second but I can have some after lunch. I also made mini skids because I was out of the ones from Currie.Have any pictures of this?
