02GreenTJ
I just cleaned thoroughly and then painted with Rustoleum.Nice work...That's on my 'to do' list as well...another month and it'll be warm enough to tackle that....what paint did you use..stonechip?
Hi @BlankThat’s looks damn good where did you get the pillar mount
I love the look of all that...it just tidy's it up abit.Grabbed an idea from another member here, installed some surface mount led tail lights as well as a plate light. I also diy'd the lic plate and frame to contour to the tub. Was easy, a bit time consuming getting everything wired and mounted correctly. It did need a led flasher to avoid the hyperflash. Another quick and easy swap. One issue, my dumbass self didn't pay attn that there was only one light per packageOrdered the other side today.
When you get to the passenger side, you may need to shift your evap canister forward a little.Grabbed an idea from another member here, installed some surface mount led tail lights as well as a plate light. I also diy'd the lic plate and frame to contour to the tub. Was easy, a bit time consuming getting everything wired and mounted correctly. It did need a led flasher to avoid the hyperflash. Another quick and easy swap. One issue, my dumbass self didn't pay attn that there was only one light per packageOrdered the other side today.
The reason I bought these, they are flush mounted to the tub. Only the wire hub coming out the back protrudes into the tub about 1/2".When you get to the passenger side, you may need to shift your evap canister forward a little.
All it took was backignout the bolts that hold it, putting enough washers in there for the clearance I needed, then bolting it back up.
Hopefully not. It is plenty visible from the rear unless at the far right of the vehicle. Of course, having two close buds that work for them can have benefitsTail lights look tits brah! Nice job with the license plate. Hopefully the CHPies won't bug you.
Is that a creeper under your Jeep or a jack?View attachment 24537
Finished up
Front 4.10 regear
Still need to replace axle u joints and front drive shaft u joints. Also waiting on new hubs and shocks
It’s possible they thought you had an axle sitting around w 5.13’s. I’ve almost purchased a rear 8.8 w 4.56. Then I’d only need the frontGot pricing from a bunch of shops around the twin cities for a regear. One of them responded asking if I wanted 5.13s in both d44s or only one. Needless to say, im not choosing that shop
