392 + 35 = 4.88How about something more realistic that can go faster than 45mph, what about it's subsequent models over the years?
I am clueless, never looked into it.
There is obviously a flaw with how i presented that question.
I was thinking how does TJ differ from everything else? Do LJs suffer this, but if they don't, then why do regeared JKs have this issue as well? Then there is a question on top of questions, all circling in the head, as well as a dilemma as to how to put it all into writing without turning it into 5 paragraphs of mind fuckery.
So lets just forget that i asked![]()
@freedom_in_4low , I corrected answer 2. The answer should be NO, if I remove the front driveshaft I do NOT get vibes. Sorry. Oversight.
The interesting cases are those who still have vibes with the front DS removed or with hubs.
I know. The hub kit is an astronomical $1589 on Amazon. I’ve got it on Price Pulse just waiting. I really don’t want to spend money on it at all. I could just drive 66mph and be fine.Thanks!
I can think of a few words more colorful than "interesting", but yes.
If the price of hubs ever becomes reasonable again I'll probably jump on them. Even if they don't solve my issue immediately, I'll eventually need them, and it sure would make diagnosis easier by not having to R&R my front shaft all the time. That was bad enough with the stock skid, now I don't have the little wrench window to get the bottom bolts on the front output yoke.
I have a bone stock 04 TJ Unlimited that has the harmonic. All it did when I regeared it is move it lower in the MPH range.to go more into this, I have not found one single example of someone picking up this vibration after a lift. There are plenty of examples of people installing a lift and tires without regearing and none with this problem.
While the operating angle does increase the amplitude of the angular velocity waveform of the double cardan assembly or the main shaft body if a single cardan shaft, but that's a second order vibration which would be double the characteristic frequency of this phenomenon. If my understanding of NVH is correct, a vibration can excite second and third order harmonics of itself, but it can't excite a vibration of half itself.
Lastly, I think pretty much everybody in the affected group is gonna be running about a 4" lift because everybody with vibes (so far) has at least 33" tires. It would be nice to find some people that regeared with no lift, but I don't expect them to show up.
Getting to the bolts on the front output shaft is a pain, but I can do it. Lots of pain.
I feel your pain. I’d prefer to buy PSC steering or Beadlocks.Since mine doesn't come on until about 73 I almost never get to it, which is why I've (regrettably) been putting it off for almost a year. But, the times I do get to it is when I'm going somewhere to wheel. The last thing I need is to have $25k+ invested in a vehicle that gets 12mpg and have a reason not to go wheeling.
Next time I do it I'm gonna swap back to stock bolts. The bolts that came with it from TW have a 7/16" head and I can't find a 7/16 ratcheting wrench that will fit around the head and not hit the yoke. So it's like 1/8 of a turn at a time the whole way. Plus I ordered my driveshaft like an inch short so that it wouldn't bottom on full droop, so I have to pull it against the natural position of the boot to seat it at the axle end. It's a bitch.
Maybe we should form a support group.It complicates my wheel selection, too. I run 5.25" BS with 1.25" spacers for an effective 4". The extra width of the hub kit means I keep the spacers and end up with a bunch of scrub radius I don't want, or ditch them and lose whatever turning radius I lose from pulling the tires 1/4" back in.
Does it go away at higher speeds? Like with a slightly out of balance tire?
the 5x4.5 kit adds about 3/4" per side. The 5x5.5 kit doesn't add any.Maybe we should form a support group.
I feel like we’ve already had the yoke bolt conversation. Worth the switch to get an 8mm or 5/16” in there
How much length does a hub kit add?
