I'm doing some front end maintenance and I've found that I have a Rubicon Express RE1600 track bar which is designed for 3.5"+ lifts. I'm under this height which means it doesn't have any adjustment and it contacts the diff. This was installed by the PO. I need to replace it but the frame side mount was drilled out for the new style joint. The only reputable brand I can find that has a similar configuration designed for under 3" of lift is the metalcloak track bar. JKS won't work and neither will stock because the hole is too big now. I'm looking for thoughts or options? Does metalcloak make a good track bar? Something I'm missing?
https://rubiconexpress.com/Suspensi...0.aspx?t_c=1&t_s=101&t_pt=4164&t_pn=R/ERE1600
https://metalcloak.com/tj-lj-xj-durotrak-track-bar-front-solid-chromoly.html
