I am still chasing a fast short cold start rattle that only happens if TJ is left for more than 24 hours, I have tried many different filters so thought I would try a crank no start to see if it is in fact oil drain back or not.
Is there a fuse I can remove to allow starter crank without starting or does the 06 have an anti flood feature (Full gas pedal at key turn crank only)?
My thoughts are that the slower cranking may bring oil up to the top end and then on proper start see whether the rattle is there , I am grasping at straws here with self diagnosis, the fast rapid metallic rattle lasts less than 2 second but I do have a slight tick for a few minutes.
Its driving me mad! once its been started it doesn't happen again even if I turn it off and re start immediately after the dry start rattle? I have read that some JK,s did this from new but not TJ,s.
I have tried to capture the rattle on my phone but just doesn't want to happen when I record lol.
cheers
cheers
