Good choice. I have a TF diff cover on the front with no clearance issues. Stockish shape, nodular iron, and a drain plug all at a price that's half or less of competing covers with these features. What more could you ask for? Put mine on with a lubelocker gasket. I will add that I'm not particularly impressed with the paint on the thing - if you haven't put yours on yet, you might consider a coat or two of a better paint.
Thanks for the heads up.
I may paint them black then. Did you have a lip on the bottom that needed to be ground flat? I read complaints on that in the past.
I have lube lockers as well. Going to order grade 8 bolts from McMaster-Carr but I need to decide if I want black oxide or yellow zinc.
