I told Santa to pay you a visit and fix everything.Dear Santa Claus:
All I want for Christmas this year is to turn the clock back to summer of 2019, before the wheels fell off this ride I'm on. Times were so much better then.
Thank you,
sab
Thank you,
sab
This is some bizzaero world shit that’s going on right now!Dear Santa Claus:
Thank you,
sab
Santa wouldn't have a chance. Coming down a chimney feet first puts one in a compromising position vis-a-vis a pissed off pup.I told Santa to pay you a visit and fix everything.I sure hope you weren't naughty.
You didn’t tell us the diameter of your tires. My Jeep had (& still does) 33” tires & the original 3.07 gears when I bought it & it was terrible. I have the 6 speed manual transmission. I went with 4.56 gears ‘ it’s great. 1st gear isn’t quite a granny gear now, but if I “fake a full stop” I can get away with just using 2nd. If I used 2nd gear from a full stop I’m afraid it wouldn’t be good for the clutch.So.. got everything torqued down and had to drop the front drive line... because I haven't installed the new rebuilt front axle w/ 4.88's and a LSD. Took it for a shakedown and I have to say 4.88's feel VERY different than the stock axles, which are 3.07's. Ended up starting in 2nd gear because 1st is now a granny gear and it's VERY short.
I forgot about that show, they beat the shit out of some of there trucks.With that obstacle I thought you may have been hanging out with the guys from "Truck night in America" lol
Took the jeep out. Things got a little tricky.
Happy we made it home considering I leaned my jeep against a wall while both front wheels were off the ground (was able to reverse out without destroying my jeep. The worst part is that three dudes told me to take that line when my brain knew the right side of the rock was the better line. I should not have listened to them. After I backed off they said "yea man I've only seen four jeeps make it on the left and three were 4 doors and the other was a modified setup"...thanks for telling me afterward (lesson learned).
Later in the evening, I realized (to my surprise) that my new Mopar ATF+4 transmission fluid was boiling while I checked codes and inspected things after the transmission went into limp mode. The engine and engine coolant were good to go. But my transmission got so hot that it charred my dipstick (never seen anything like that before).
Thankfully, we made it back to the pavement and the jeep drove just fine on the road (air-cooled). Need to purchase a remanufactured transmission asap (likely from Bullripper) and get the better external cooler installed when I visit Blaine.
Dang!Took the jeep out. Things got a little tricky.
WTF?!!
Dang!
Had a guy "Spotting" for me in a rocky creek bottom that I'd been in before without a spotter. He steered me into a rock on one slider (no big deal) that I didn't touch when choosing my own line. I stopped when I got up to him and said, "Hey Randy, if I need a spotter I'll let you know". I don't think he was pleased. Maybe Rubicon or Moab but on the trails we run I don't see the need. Watching his hand signals just kept me from seeing the line and doing what I know how to do.
Glad it isn't more major for you.
I'd be interested in seeing a photo of this if you have the time to share.Painted my UCF aluminum engine skid. Cast Iron Block color I had laying around with Duplicolor etching primer underneath. I like it. Figure some protection from corrosion was in order.
The primer on the plate is a green hue, all they had locally in self-etching.I'd be interested in seeing a photo of this if you have the time to share.
Must be a burned out bulb?Drove it home last night then back to work this morning with no check engine light both directions
Any ideas where I should start checking for the problem?
Oh, GREAT, an electrical issueMust be a burned out bulb?
