Dear Santa Claus:
All I want for Christmas this year is to turn the clock back to summer of 2019, before the wheels fell off this ride I'm on. Times were so much better then.
Thank you,
sab
And in 2019 we wanted to go back to 2016… who knew that David Bowie and Prince were holding the fabric of the world together.
Yep, remove the black tape and all will be well!!! :ROFLMAO: :ROFLMAO:
That's how I avoid the check engine light on all of my vehicles (black tape). Is that racist? :unsure: If I have an actual problem, the vehicle won't run good. That light is just like my gas gauge light, I ignore it until I can't. Then I push to the nearest gas station. :mad:
p.s. I bought a V8 Cadillac years ago that read my current MPG in "Real Time". It depressed me.......TAPE!
It was a moment of joy to drive this old heap again after 4 months of tearing out the old frame and putting in a new one and a transmission rebuild which I had never done before. Everything works perfectly. Last couple of pics from this project.
This is what the old frame looked like after I got it out from under the tub.
New frame and a few shots of the tub
View attachment 331154View attachment 331155
Nice work. 👍
p.s. Is that lift adjustable? ;)
Mmmmm. I loves me some Mango
Less PO hackery...now I want to find a chase module...or build my own... couldn't find three wire high low pin lights...this will do for now...was tempted to get the welder out, fill the original hole and redrill...settled on a couple of fender washers painted and drilled out...
View attachment 331198View attachment 331197
I had to do the same thing, but I had the three wire LED's from Poison Spyder. I cut all the wires exactly how they described in the instructions. The technician and I worked for three hours over the phone to get it to work but no such luck. In the end I drilled a new hole and bought two more lights and wired (according to my state motor vehicle laws) a dedicated turn signal and a dedicated side marker.
