The DC rust being covered has something to do with the problem, IF you look closer.
I’m not sure the rust where the spring sits is affecting it. I wire brushed abs wheeled the entire are, painted it with rust reformer and then some POR 15
Just reply to your thread, you can reply with something like 'Bump to the top' for more help'. That's how we all do that.
lets see some other angles... im interested in how your track bar is affecting this. some photos from the front would. be good. is the driver coil also bending in under the frame?
if you disconnect track bar and steering does the problem go away?
you can put weight on it without the steering or track bar hooked up, there is enough triangulation in the arms to keep it from doing anything too stupid.
Your control arms look stock from what i can see.
Sure! I don’t have the wheels back on yet does that matter?
Sway bar is disconnected along with end links and lower CA’s are loosened.
As the suspension droops, the axle will move back and can cause that bow. If your trackbar is connected, you have more bind on the passenger side and the driver's will droop lower. I would like to see you put the wheels back on and lower it down on its own weight. Then take a picture from the driver's side and the front. Try to get the whole front end, vs just the spring.
links and swaybar not necessary, tires not necessary, you can put the axle on stands and put the vehicle weight on the springs.
Btw your lower control arm axle end brackets are slotted, and have a round cam washer in them for alignment stuff. if you've got them out of whack it could be throwing that side off or contributing in some way.
you should always fully tighten and torque your control arms at ride height for bushing preload.
for the love of god put some jackstands under that axle
Typically it’s held up with the jack you see and another jack as well.
The 2 stands I have are under the frame.
if the frame is touching the jackstands in the middle, you dont have the front axle at ride height because the springs are not fully compressed.
if it is off the stands in the middle of the rig then your giving me a heart attack
I needed to get it to full droop in order to install the springs.
Still learning a lot here from you guys so any constructive criticism is helpful and appreciated
I promise you the 2 jack stands are firmly on the frame right behind the control arms. One on each side.
I’ll put the tires back on and snap a pic.
I just don’t currently have the brake calipers on because I’m replacing them.
Does that work?
no problem with learning and we want to help you out but when i see a rig balanced on a bottle jack with a head the size of a quarter I want to... idk run? we need to get you some more stands and a decent floor jack before we start working on setting bumpstop length etc
Also never fully trust any jack without a stand or at least a wheel and tire laid under the Jeep.
Don't forget "Esteemed Ducker",
