Front Driver Side Coil Bowing
ChadRay13
Florida
Once you have the Jack stand under the axle and not under the frame, I’m curious to see if the body sits level.
Disregard - I was curious if they had difference spring stiffness but he swapped side to side.
Reactions: AaronPaul
AaronPaul
AaronPaul
Washington DC
Did the stock spring "bow" at all? How much of the frame was replaced and who did it? Did they "cap" your original frame, or did they cut out and replace sections?
No the stock spring sat fine. No idea how much was replaced tbh.
Wasn’t me who had it when it happened
AaronPaul
AaronPaul
Washington DC
As the suspension droops, the axle will move back and can cause that bow. If your trackbar is connected, you have more bind on the passenger side and the driver's will droop lower. I would like to see you put the wheels back on and lower it down on its own weight. Then take a picture from the driver's side and the front. Try to get the whole front end, vs just the spring.
AaronPaul
AaronPaul
Washington DC
lets see some other angles... im interested in how your track bar is affecting this. some photos from the front would. be good. is the driver coil also bending in under the frame?
if you disconnect track bar and steering does the problem go away?
you can put weight on it without the steering or track bar hooked up, there is enough triangulation in the arms to keep it from doing anything too stupid.
Your control arms look stock from what i can see.
Here ya go
dw0783
Michigan
But if those are the safety caps repair sections that they look like he won’t have the frame holes called out to reference to..
AaronPaul
AaronPaul
Washington DC
Yeah I’m not sure tbh. It may just be what it is and I can’t have a lift.
The OE coils were straight as an arrow
dw0783
Michigan
After going back and looking at your pictures again it doesn’t look like you have the drivers seated correctly at the top. Not sure if this would cause that much of a bow, but it is something.
AaronPaul
AaronPaul
Washington DC
You know I hope it’s that but I have the pigtail situated firmly into the slot at the bottom so I’m not sure how I’d situate it any differently unfortunately
dw0783
Michigan
Jack it up and shift the top of the coil towards the rear. There may even be an indent in the isolator where the factory coil was seated and your spring just isn’t going into it. The factory coils were a different length so the top tail may have been in a different location. If that’s the case just rotate the isolator so it matches.
AaronPaul
AaronPaul
Washington DC
This is currently drivers side
AaronPaul
AaronPaul
Washington DC
But then the lower pigtail won’t be in the slot if I do that
dw0783
Michigan
No you can rotate the isolator on the top, that rubber piece that the spring sits against is just slid on over the post. But that spring definitely looks too far forward as well.
AaronPaul
AaronPaul
Washington DC
I can try spinning the isolate itself sure
But as you see the coil is actually running up against the coil tower.
