Options after Metalcloak track bar
Catch 22
Nashville Tn
I installed a MetalCloak front track bar and after 2 years of dealing with worn joints and wobble I'm out. The frame size is drilled out to 5/8th giving only a few options. Currie can pick up the slack there but the axle side is drilled out to 9/16th from the MetalCloak TB. My understanding is the new CE-9120TJS comes with a JJ on the axle side and it uses 1/2 bolts.
I'm looking for options to address this.
One was to try and see if a MOOG K7252 Track Bar Bushing would fit. Yes its a step back from the new JJ end but its sized to 9/16.
Is anyone aware of any other options I might consider - to address the bolt size issue?
I plan to. I need to know how to address the bolt issue at the axle.
Tighten the bolt. There is nothing to address. I had the MC bar on mine. Now I have the RJ with JJs on both ends.
Reactions: rasband
So the 1mm gap between the 9/16th hole and the 1/2 bolt wont be an issue that would induce lateral movement of the axle?
I'm not expert but this feels....wrong. Happy be to incorrect but that's why I'm here.
This is a daily too, not a trailer queen or just offroad. I need it steady on the road.
Reactions: Jerry Bransford
It's not a problem when the bolt and its nut are correctly tightened to the correct ft-lbs. with a torque wrench. Really. :)
Non issue. Bolts work with clamping force. Look at your front axle lower control arms. How do they stay in place inside the slotted holes?
Reactions: Irun
Mine is a daily, too. And that's the RockJock track bar.
.0625 divided by 2 = .031 per side which is a lot smaller than the area in the slot on either side of your front lower control arm bolts.
Reactions: ranger101
