I installed a MetalCloak front track bar and after 2 years of dealing with worn joints and wobble I'm out. The frame size is drilled out to 5/8th giving only a few options. Currie can pick up the slack there but the axle side is drilled out to 9/16th from the MetalCloak TB. My understanding is the new CE-9120TJS comes with a JJ on the axle side and it uses 1/2 bolts.
I'm looking for options to address this.
One was to try and see if a MOOG K7252 Track Bar Bushing would fit. Yes its a step back from the new JJ end but its sized to 9/16.
Is anyone aware of any other options I might consider - to address the bolt size issue?
