Oh come on @mrblaine, do it the hard way. I’m listening and would love a good suspension dynamics lecture with pictures/video. Please!I've played this stupid fucking game with you before Bill. Let's do it the easy way, go fuck yourself.
OK, guess I’ll educate myself elsewhere. Who knows what that will result in![]()
.... There is much more variance on the types of terrains that I wheel on to put to much emphasis on 1 specific measurement.
IMO Trackbars count as links, so 5 link is 4 control arms plus trackbar, 4 link is either 3 control arms and track bar, or 4 control arms triangulated. 3 link/4 link is IMO actually 4 link 4 link IMO... I have run all of the above, and perfer 3 link/4link but the 5 link factory style has saved my bacon when I snapped a control arm completely in half and could still drive home. I don't buy into the exact math for CG etc, as long as it's close and not off by a retarded amount there is plenty of wiggle room. There is much more variance on the types of terrains that I wheel on to put to much emphasis on 1 specific measurement.
Bill M.
What is this one specific measurement? And what is its variance for different types of terrains?
Doesn't matter anyway since you can't model it very well dynamically which is the only place it matters. The very best you can do is build it and go test it, the rest is a mere suggestion. You can fuck up a 5 link on the street just as easily as you can't so to state that a 5 link is inherently better is highly flawed logic.
Come at it from the other way. If as he has suggested, he has the ability to do what he is saying, then it is not difficult or hard for him to explain his point of view with some suspension designs that illustrate his point and easily clarify his definitions for what he calls a 4 and 5 link set up.
Point- The Savvy short arm like most short arms is a 4 link front and rear with trackbars. That technically makes it a 5 link front and rear. See the problem now?
To drag the Bomber into any thread about suspension on a TJ or TJ Unlimited is ludicrous.
Isn't "Fucktards" is a term of endearment?![]()
What I found on mine was that while it made the calculator have better numbers, it did not translate to real world performance very well on the trail. This is why Blaine mentioned the best simulation you can do for suspension is to build it and go test it.But for starters, I’ve seen it said here more than once, that increasing separation by lowering the frame side lower link attachment is not really of value in a short arm TJ with 4” of lift. Why?
What did you do, exactly? What were you trying to accomplish? Did your changes make no noticeable difference or make something worse?
I agree Blaine, fuck those engineers and their fancy computer aid designs that the successful trophy truck, KoH Nascar, Indy, Formula 1 and OEM teams use to win. Just resort the old caveman dyno design system.
