If you have some wisdom to share, please do.
He doesn't
Ok, I’ve got a question on link’s IE 5/4/3
Are we counting them as how many bars/arms attached to axle, or frame, or in total.
So like a triangulated 3 link. Three mountain locations on axle but 4 on the frame.
Radius arm, five mounting points on axle but 3 to frame.
Honestly wondering how you all would categorize this, I would think by mounting points on the axle.
Good question,
I think if you asked a Jeep engineer they say a stock TJ front a rear suspension is a 5 link design because they are counting both longitudinal and lateral link bars, thus the track bar is included. Chris Alston, who was a leader in the "4 link" world does not count the track bar in his design although he does have one.
So lets take a the rear Savvy design triangulated mid arm, it has 4 bars and each articulate independently and the lateral movement of the axle is controlled by the upper links triangle arrangement, there on track bar. So that would be a 4 link suspension.
But a front suspension with 3 longitudinal links, two lower and one upper and a track bar could also be a 4 link suspension but some may call it a 3 link.
Then a rear suspension with 2 longitudinal links and a upper wishbone could be called a 3 think but so could a early Ford Bronco front suspension with 2 fixed at the axle longitudinal links and a track bar.
Are you confused enough now? This why 3/4/5 link terminology can be hard to nail down in a conversation.
I think I get the 4 vs 5 link terminology (5 link uses a track bar for lateral stability vs triangulation for a 4 link). Arm length, angle and separation and all the impacts on instant center, pinion angle, anti-squat/anti-dive and how all that translates into the real world is gonna take some time.
But for starters, I’ve seen it said here more than once, that increasing separation by lowering the frame side lower link attachment is not really of value in a short arm TJ with 4” of lift. True? If so, why?
Oh come on @mrblaine, do it the hard way. I’m listening and would love a good suspension dynamics lecture with pictures/video. Please!
Thank you for the compliment. I have to agree never stop learning.![]()
There has to be a point where we all agree that we're on a forum primarilly devoted to the Jeep TJ....
I look at what is winning in the racing world that most closely approximates the application I achieve.
In the case of a desert runner/rock crawler it would be the Bomber chassis. If you look at a Bomber it lower links both front and rear, are what the TJ world would call long arm, are parallel to the ground and the upper link triangulates, has an instant center that seem to pivot at the out shaft of the transfer case. Definitely there is a effort to keep the CG as low as possible, just look at how low the belly skid plate hangs. Shock travel at ride height seems to 30% up 70% down.
Bomber are winning so I would follow Bomber's lead.
Just so we can all see what Bill is referring to. Once again, the answer is a tube frame.
What kind of shock travel do those run?
@Chris, please change the name of the forum to reflect this. Thank you.
Kinda the wrong question, the correct question is how much wheel travel do they run and that is generally depends on the motion ratio and what they are doing but figure 24-30".
That's why I was saying what I said. A buggy might be faster than a TJ to the top of the rocks, but this isn't a buggy forum...
So on the low end 7” up and 17” down with a 30/70 split.
