LCoG and long arm lifts
Do you keep at it like that, repeatedly pushing back, just to piss people off? Blaine built that rig from scratch, I saw it while it was being built many years ago. He already told you the axle lengths are not 70". Once again, per Blaine.... "Front is 65 and rear is 64 on Walker Evans bead locks with 4" of back spacing and 37's".
That and the widest front axle I have ever installed is 68" for 40" tires on 4" back spaced rims. I've done many of those.
Jon's rig has a back half we built (never again) to get the coil over springs to clear. The outer face of the back half is the old inner face of the frame and we had to notch into that by nearly an inch at full articulation. I no longer listen to what they want and instead lean the coil over back just enough to get it out of the way of the tire apex. Don't have to notch quite as much that way.
This is 68" front, 67" rear, with 40's and 4" of BS.
What was the thought or the advantage behind not leaning it back?
The why of some of the wider track widths is turning angle.
edit- We pull the rims in as far as is reasonable based on what is available. If you look at the vertical bolt on the left side steering knuckle, you can tell we've got the rim inward just about as far as is reasonable. That is done to keep the steering working as well as we can get it. We would build around a wider axle and run 5" or so backspacing if we could always be sure we'd clear the steering arm on the knuckle. Only slightly wider but we'd move from 65ish for 37's up to something a bit more.
Is this why the front is an inch wider than the rear on the rigs you’ve mentioned so far? If 68” width is needed up front for turning, what is the reason behind making the rear 67 and not 68 as well?
I try to maintain the factory track width relationship. The rear is narrower and I keep that to help offroad some.
Just so we can all see what Bill is referring to. Once again, the answer is a tube frame.
Here is what I am referencing to. See how flat the links are and how low the belly is. I would define the Bomber as a long arm low CG design.
P.S. At least get my name right, it is John not Bill, but you can address me as "Sir". Thanks 😎
  • Face Palm
Reactions: psrivats and jjvw
Those are beautiful machines... but I don't see any jeeps in that picture.
some of us are interested in offroad suspension in general, knowledge that translates outside of that specific to the TJ, and would like to see some of these ideas discussed instead of just shouted down because it's not a Jeep.
If we really need to keep it TJ related, then I suggest specifics of why a certain philosophy that works in a buggy doesn't work in a TJ.
If you spent any time on trail with them you'd learn a few things, they don't crawl very well at all. They haul ass very well. They have full hydro steering and they aren't as much fun in the rocks as you would like unless you like to bomb through stuff.
Reactions: kmas0n
They look like they'd be really good at this
Reactions: Lightning
how would you change one to shift the balance more toward crawling?
Interesting. But still not relevant to what the thing we are building here. Also, I don't know or care if the Bomber builds are LCoG or not. What I see are people building within the constraints of the platform.
