2001 Radiator Replacement (Champion Aluminum)
Alatex
Alabama
Well, I did a thermocure flush and fixed my overheating issues after months of trial and error after replacing my water pump and today I popped the hood while it was running and saw a tiny crack in the top of my radiator. There are only about 15 threads on radiators going currently, can someone tell me which radiator I should get? I’m assuming that I won’t be able to locate an OEM one. Champion? Cold Case?
Edit: Before someone says anything about reading the current threads on it, I’ve skimmed most of them and can’t seem to find a consensus. Anyone with current experience running something other than OEM would be preferred since we’re all going to have to make the transition eventually. I might as well start now.
Update 1/5/2023: This thread should now be viewed as a long term review (or short term if it dies quickly) of the Champion Cooling Systems All-Aluminum Radiator for 1987-2006 Jeep Wrangler
Part Number: 166-EC2101.
If I couldn't find an OEM, I think I would go with the all metal CSF. I put one in my YJ decades ago and it has never had an issue. And if it does, it can be repaired.
Reactions: Willys LJ
Just out of curiosity what engine do you have in your YJ?
Geeezzz...you guys act like if you dont get a Mopar rad its the end of the world and the thing will never run again. Are they better, sure but for the cost of one mopar you can buy 3 brand x rads. So I ask, what about the other 90% of the crap import parts we get now a days or the parts for the other vehicles you might have. The non mopar in my XJ, TJ and YJ are all brands X and have yet to self destruct in years. The YJ sees 90% AZ or NM trails as well. taint the end of the world ya know.
Rock Auto
1994 Wrangler 4.0L
CSF 2576 - $288 ea (2 rows)
CSF 2578 - $325 ea (3 rows)
Copper core/Brass tanks...
Will work in ALL 4.0L 87-06 Wranglers (YJ/TJ/LJ)
I have been running them for years in my 2006 LJ. They last about 3-4 years. Compared to 12-15 months for the Chinese-built aluminum replacement POS radiators. I could probably get the copper cores to last longer if I were to remember to change out the radiator fluid every 12,000 miles.
Before someone calls running a copper core radiator in a 97+ Wrangler blaspheme stop and consider for one moment the 87-95 YJs 4.0L use the same small block design (metallurgy) as the 97-06 TJ/LJs. Chrysler switched from copper to aluminum core radiators for cost savings and weight reduction - NOT cooling performance.
Reactions: astjp2
Yeah I honestly haven’t even looked for a mopar one and I’m ready to commit to an aftermarket, just want input from folks that have used them and their suggestions so I can get one that will work
Ok so extreme terrain appears to have an all metal 3 row CSF for $184, why is it more expensive other places?
Who wants to change a radiator every 3-4 years?
Not to mention, they rarely fail sitting in your driveway with a spare on the shelf.
  • Love
Reactions: Zorba
I'll throw in the unpopular opinion of buying a Napa radiator. Mine was made by Spectra...I think the current batch is made by Agility. Mine's at least two years old and no issues...yes...one case is statistically irrelevant. I like Napa cause I know they'll support their products and I can walk into the store and look the manager in the eye.
I think the CSF options and find an unobtainium Mopar are all great options...I'm just allergic to spending $300 plus on a radiator.
PS Agility bought APDI in Aug 2021. Napa radiator costs $172 and thats more painfully close to $300...damn inflation.
Reactions: mikespine
Does the year matter? Will they all fit interchangeably?
For a manual trans, I think 87 to 06 are interchangeable. I have heard that some of them have different shroud bolt threading than OEM, but that's all I can think of.
If you can find oem,Buy once,cry once
  • Face Palm
Reactions: LONGJP2
