Which fuel injectors do I need?
Ortegadominick3
Tacoma Washington
I got a p2096 code on my 2005 jeep wrangler sport 4.0. I’m not sure if it’s the fuel injectors, but I have about 110,000 miles on it anyways and wanted to change the fuel injectors. I’ve looked online and I couldn’t get a definite answer on what fuel injectors I need does anyone know which ones I need or where to look to find the answer ?
Watch out for the recommendations to go 4-hole injectors. They seem to be a 'seat of the pants' upgrade that the computer quickly removes. That's been what I've surmised from the community anyway.
Just do your research on that when someone inevitably tells that's the answer....
Have you actually pulled and tested one? Why buy something you might not need?
I'd start with the O2 Sensors.
I have replaced my downstream bank 1 02 sensor. I used ngk for the brand. My check engine light went away for about 150 miles and came back. My fuel injectors seem to be working fine, but my mpg has gotten a little worse so I figured I can replace my fuel injectors
A 2096 is more likely to be an exhaust leak or bad O2 sensor than injectors. Do you have a misfire?
Reactions: williambmac
This.
For an injector to fail at a little over 100K is rare. I'd replace your other O2 sensors and see what happens.
As to the injector type. I'd match what's in there. Don't buy into the more holes the better performance stuff. Not with this engine.
Just take the injectors to a injector shop and have them cleaned and flow tested, but replace all the o2 sensors before that. Your 05 has 4 hole injectors stock I believe.
Reactions: gatertamer
You need to replace the top 2 O2 sensors as they are the ones that control the mixture. The bottom O2s are mainly to monitor the cat efficiency.
If you replace the injectors, you can go back with stock 1 holes, or pick up a refurbished set of Bosch 4, or 12 holes. The ones with more holes have a better spray pattern, that is the only benefit. You aren't going to see any big improvement from them over a clean stock injector though.
Usually the claims that 4 hole are better is because they are replacing old clogged up single hole injectors.
Both new, you won't notice side by side.
  • Love
Reactions: Jerry Bransford
Injectors in some engines are designed to be a more of a stream to spray on the back if the intake valve. It's supposed to help atomize the fuel, cool the valve and clean the deposits.
Reactions: MikeE024
I’ll try to replace the all the other 02 sensors and see what that gives me first. Appreciate the feedback !
Did you ever replace the remaining 02 sensors? If so, did it resolve cel problem. I have had this same issue for some time. I also replaced the one sensor and ran code free for a while, but now it comes back within 50 miles or so. P2096. Thanks
What brand of O2 sensor did you install?
There is a TSB on that code for a ECM Reflash
NUMBER: 18-028-06
GROUP: Vehicle Performance
DATE: September 15, 2006
SUBJECT:Flash: MIL Activation For Downstream Fuel Trim - DTC's P2096 or P2098
OVERVIEW: This bulletin involves selectively erasing and reprogramming the Powertrain Control
Module (PCM) with new software.
MODELS: 2005 (TJ) Wrangler
NOTE: This bulletin applies to vehicles equipped with a 4.0L engine (sales code
ERH).
SYMPTOM/CONDITION: The Malfunction Indicator Lamp (MIL) is illuminated and Diagnostic Trouble Codes (DTC's)
P2096 or P2098 are stored.
DIAGNOSIS: Using a Scan Tool (DRBIII®) with the appropriate Diagnostic Procedures available in
TechCONNECT, verify all engine systems are functioning as designed. If DTCs other than
P2096 or P2098 are present record them on the repair order and repair as necessary
before proceeding further with this bulletin, then perform the Repair Procedure.
Also make sure you don't have any exhaust leaks that may be skewing your O2 readings.
